Author Topic: Been busy, pic heavy...  (Read 3161 times)
« on: May 07, 2017, 04:44:41 PM »
I have been busting my butt to get so much done. Lets start with the moose, Xena is 4 years old and started limping so I built a ramp from a very heavy pallet. I got it from a counter top company, it was used to ship granite slabs.
She's almost 200 lbs and NOT FAT.
Pleas excuse my sewing mess.
I also finished the dining room floor and am starting the living room. it's coming along nicely.
Now for the newest D.I.Y. Lunacy. I'm trying to make a light weight net tent to use with or without my hammock. This will go up with or without my big tarp as well. Let me know what you think.
The big tarp.
zipper needs some webbing added to the ends to close the gap. I think I'll make end walls out of ripstop to get the ends closed. Not even sure how to stitch this all together....
I also have new knobby tires on the lawnmower, cleaned the yard in prep for a rear deck, and recently acquired a motor for my 1971 craftsman garden tractor. I will be installing that as soon as the weather dries up. I got almost $200 for the metal I took to the scrap yard too!!
I need a vacation!!
Re: Been busy, pic heavy...
« Reply #1 on: May 07, 2017, 05:53:08 PM »
looks good.
i have an idea for the end flaps... full disclosure though, it's just an idea, i've never tried it myself so it may or may not work....
cut the ripstop that you need to fill the gap, the whole triangle.
sew a zipper down the middle of the ripstop.
unzip the zipper and burn/cut the ripstop to make a zipper hole.
then sew the rip stop to one side of one end
then sew the rip stop to the other side
repeat for the other side, if it worked...
« Reply #2 on: May 07, 2017, 05:55:57 PM »
also, here's a really good diy net tent write up
 https://www.yamamountaingear.com/diy/net-tent/
« Reply #3 on: May 07, 2017, 06:20:37 PM »
When you say you've "been busy" you weren't kidding.....that's a lot of irons in the fire all at one time!  Have you had "the moose" to the vet?  Sounds like it could be hip dysplasia.....I hope not! :-\
« Reply #4 on: May 07, 2017, 07:23:36 PM »
Funny...the "irons in the fire" phrase came to me, too.  You are as bad as I am...start a new project before the first one is done.  :-\
I'd get Xena check out, too.  I lost a Malamute/Wolf xbreed who hit 175 lbs at 7 months old and suddenly couldn't get up without screaming.  The x-rays of his hips were heart breaking.
« Reply #5 on: May 07, 2017, 07:31:03 PM »
I'm digging the sleep system. I'm glad I have a little dawg.
« Reply #6 on: May 08, 2017, 05:39:44 AM »
Thanks. Xena has trouble with her front wrists. sometimes hold one  or the other up for a while. Then she's good again. She just bled off so in about 6 weeks she will go in for spaying. It's gonna be costly with her weight but it needs to be done. She needs a heart worm test too. Never had one. She gets bad anxiety, drools a lot, and often vomits when riding in a moving vehicle. I did find she ride good in the back of the truck with my pallet sides on it. Seemed very happy back there, like maybe she's claustrophobic..
Yes, i do like the idea of zippered ends. There is a huge community garage sale event this weekend. I'll dig up some cheap stuff for the zippers. I'd like to find an old tent for the fiberglass poles too.
I'll add that the Honda is done and I've been riding it around. It has a huge flat spot in the mid range throttle position. I replaced the coil and re checked the timing. I even pulled the carb and dropped the circlip down a slot to richen the mix, it helped. I'm going to pull the carb and run a cotton wick down the high jet to make sure it's clean. If that doesn't work I'll raise the high needle one more notch. Good compression, no smoke, no leaks, and starts on the fist kick!!!!!!!
« Last Edit: May 08, 2017, 05:51:15 AM by xj35s »
« Reply #7 on: May 08, 2017, 09:02:41 AM »
Busy guy.
I like the flag on the wall.
« Reply #8 on: May 10, 2017, 03:52:48 PM »
I have had a great deal of trouble trying to upload to photobucket. It keeps going back to the login screen even after acknowledging that I have logged in. It does it every time I click upload. These photos are shared using Imgur. Much faster and easier. We'll see how long they stay up!
I have to give a shout out to my brother in law. He gave me this 8HP Briggs. I have it all mounted and it runs great. I need a belt that's about 1 1/2" longer as it will not disengage right now.
I actually measured, drilled, tapped, and then bolted the engine on. Kind of proud of myself that the holes all lined up perfectly and torqued down tight. As this came off a snowblower I don't believe it has any generator. It does have a starter that plugs into 110v. I don't think I'll need it, it starts easily on the first pull.
For a reference, that angled piece in front of the fuel tank bolted to the head of the HH100. It is a much bigger engine for only 2 HP difference.
I am now going to tear down this original Tecumseh HH100. I'm going to guess the cylinder is egg shaped and in need of a bore. My brother did hone and replace the rings 20 years ago. I know for certain the connecting rod needs attention. We'll see if I can get it rebuilt.
« Reply #9 on: May 10, 2017, 05:21:19 PM »
Nice job.
You do understand that Tecumseh is an old Indian word for "leaks oil"?
« Reply #10 on: May 10, 2017, 06:16:02 PM »
Does that Briggs have an air filter?  Most snow blowers don't....might need one on a mower. :rofl:
« Reply #11 on: May 10, 2017, 06:52:23 PM »
Nice!
Wish I knew about meshinery.  In my jargon, "drill and tap" means drill a hole and tap the burrs flat with a hammer....  :lol:
« Reply #12 on: May 11, 2017, 06:15:48 AM »
No air filter and you are correct. I do have an airbox that will bolt on.
« Reply #13 on: May 13, 2017, 08:04:08 AM »
Okay, here we go. At the Radisson housing community garage sales we found this large stack of finished tongue and groove for $1. There are a bunch of smaller pieces in the box too.
When we pulled the carpet it left this section on the wall exposed to the chip wood. It is kind of a cross between the cedar walls and the Oak laminate floor. I hope it doesn't look stupid, the carpet going up the wall did I thought.
I am going to cut it so it goes on vertical and will be perpendicular to the flooring, but it'll match the cedar wainscoting direction. If there is enough left over, I'd like to wrap/box in the step with it as well.
WOW! Yes, I need a garage and yes that's a welder in the kitchen!
« Reply #14 on: May 13, 2017, 08:59:08 AM »
Dayum, you have been and are, busy.  That will look nice on that step down.
« Reply #15 on: May 13, 2017, 09:14:14 AM »
If it's true that "busy hands are happy hands" yours must be giddy! :rofl:
Nice work on some pretty involved projects! :hail: :cheers:
« Reply #16 on: May 14, 2017, 12:20:01 PM »
Thank you. Yesterday the wife say's we need to paint the room before we finish the floor. Yup, it is a good idea I guess. We ruined the walls with the fire wood. She mudded the sheet rock and sanded it for paint.  I still have to go over the edges a little better. Not sure it's as bright as I wanted it to be.
« Reply #17 on: May 16, 2017, 03:43:31 PM »
I was getting very disappointed with the garden tractor. no power. I thought 2 HP can't make this much difference. So today I decide to mess with it a little more to diagnose maybe a carb problem.
I opened the high jet a 1/4 turn. WHOA!!!!!! Amazing power difference. I can pop wheelies now. The moose (Xena) bit the front tire and now the tube is coming out of the center of the tire. She stopped the tire and lifted it off the ground. All while running backwards. Yes she still has all her teeth.
God help anyone that comes in when we aren't home...
« Reply #18 on: May 17, 2017, 04:53:48 PM »
« Reply #19 on: May 27, 2017, 07:24:57 PM »
The piece I've been looking for the last few weeks!
Now the Bike, floor, buggy, and lawnmower are done.  I need to do the 1/4 round trim along the walls and finish up the short wall by the kitchen. Then I can officially call it camping season.
« Reply #20 on: May 27, 2017, 08:04:32 PM »
That is a whole bunch of work, you deserve some woods time.
« Reply #21 on: May 27, 2017, 08:07:33 PM »
Looks great!
 :cheers:
« Reply #22 on: May 27, 2017, 09:37:42 PM »
Nice work!   :thumbsup:
« Reply #23 on: May 27, 2017, 10:05:41 PM »
You must be looking to ask the wife for something REALLY big this time.......and you deserve it! :lol:
« Reply #24 on: May 28, 2017, 12:58:21 AM »
Thank you. New furniture coming soon I hope.
We picked up 2 baby mattresses and I'll be building a wide couch for the dogs out of wood pallets. Also want to build a corner nook love seat with a bookshelf behind it. Sort of kneel on it grab a book then sit and read.
I still have 15 feet of concrete pad on this end of the house. I wanted to make the a sun room on the south side and a library on the north side. Not going to now because we stack the firewood on there. Maybe someday.
« Reply #25 on: July 10, 2017, 10:45:54 AM »
When we first bought the house we argued that the windows weren't sealed and air came right through. They inspected them and assured us they were right and it was the "weep holes" causing the draft.
Forward a few years and we had an energy audit done while contemplating solar panels. Low and behold the windows leaked. A LOT!!! It was the only fault that we could fix. The recessed lighting was the other issue but there is only 8" of space to work with in the ceiling.
When we took the cedar boards off he windows we could easily look all the way to the vinyl siding all the way around the frames. So I bought a professional spray gun for great foam and sealed them all up good. It was expensive but I kept breaking the plastic nozzles on the small cans rendering them garbage while still quite full. The nozzle was $41, $12 can of foam, and $8 for a can of gun cleaner.
So we now have our new furniture and the window curtains. Now I just need to clear the clutter and it'll be home sweat home again...
The bottom left corner is the baby mattress I wanted to make the dog bed out of. They won't lay on it. I don't know why, maybe the plastic wrinkling sound it makes? Soooo, no dog bed but they aren't allowed on the new furniture!
« Reply #26 on: July 10, 2017, 06:25:33 PM »
Yeah, I always liked the Stars and Bars.  Not sure why folk are so unhappy with it.  Plenty of African slaves were owned by people up north but nobody remembers it.  Only a tiny fraction of the Confederates held slaves and they were mostly the wealthy land owners.  The ones who fought got conned into fighting for an institution they had no part in.  Heros need to be remembered.
« Reply #27 on: October 14, 2017, 06:17:06 PM »
I just got the short wall and stairs finished. I think it came out decent. I have cedar stock for the border to hide the gap along the floor and wall.
« Reply #28 on: October 14, 2017, 08:42:05 PM »
That is very nice.  Lots of options but that one really looks good.
