Author Topic: Neck Knife Build Along (WIP)  (Read 5124 times)
« on: July 11, 2017, 01:14:44 PM »
Working on a trade with one of our members.  My end of the deal was to build a neck knife.  I started Sunday and thought today that I'd do build along, or work in progress thread.  I didn't take pictures of a few steps, but will explain.  I will take pictures of the rest of the steps.
First the steel.  Thought I'd use a rusty sawmill blade.  The blade with the larger teeth started out as a 54" blade.  The smaller one was about 30".
Next was to cut out a couple of pieces - one from each.  I used a 4" angle grinder to cut two pieces that were about 4" X 7".  Next I annealed them in my oven over night.
Next was to cut some strips with my portaband band saw and knock off some of the big chunks of rust.
Next was to profile the blade.  The secret to profiling is to remove the parts of steel that don't look like a knife.  Sometimes that works, sometimes the grinder and steel have a mind of their own.  This is what I came up with for a profile.
I'll get back to it after supper tonight.
Re: Neck Knife Build Along (WIP)
« Reply #1 on: July 11, 2017, 01:20:06 PM »
Looks good to me.
« Reply #2 on: July 11, 2017, 03:29:13 PM »
So far so go. Looking forward to the finish.
« Reply #3 on: July 11, 2017, 05:34:34 PM »
Cool! I'll be following.  :popcorn:
« Reply #4 on: July 11, 2017, 06:06:13 PM »
Since I don't like to fire up the heat treat oven unless it is full (process is just so time consuming), I profiled a few more and drilled them.  Next up is the heat treat process.
« Reply #5 on: July 11, 2017, 07:50:45 PM »
COOL.....service for 8! :thumbsup:      I'll be tuning in, too. :popcorn:
« Reply #6 on: July 11, 2017, 09:31:12 PM »
Nice Crash!  I'll be following this one too!
« Reply #7 on: July 12, 2017, 06:13:57 PM »
Heated the blades.
Quenched in Canola oil.
They are going through a temper cycle now.  Will repeat the temper cycle in the morning.
« Reply #8 on: July 12, 2017, 08:45:27 PM »
You weren't kidding about filling up the oven!
Nice work!
« Reply #9 on: July 13, 2017, 06:40:19 AM »
Cool.  What are the specs of these crash?
« Reply #10 on: July 13, 2017, 02:01:50 PM »
Thanks for the update and pictures.
« Reply #11 on: July 13, 2017, 06:35:43 PM »
I'll measure everything when I'm done.
« Reply #12 on: July 13, 2017, 06:43:50 PM »
The heat treat is done.
Time to work on one at a time.
Grinding.
More grinding.
Grinding with a 50 grit belt is done.
Grinding with a 400 grit belt is done.
The scales are from 2500 year old bog oak.
White liners seem appropriate.
Ten pound of BB's to help set them in place.
« Reply #13 on: July 14, 2017, 07:10:15 PM »
Tonight was attaching the scales.  Tomorrow I'll shape them and work on a sheath.
« Reply #14 on: July 14, 2017, 08:14:31 PM »
I like those bamboo-skewer pins that you've been using......a little different than the run-of-the-mill nickel or brass that you see most of the time.  Mosaic pins are a little too much for my tastes. :shrug:
« Reply #15 on: July 15, 2017, 06:25:31 PM »
Wet forming is done.  The sheath needs to dry overnight.  Should finish things up tomorrow.
« Reply #16 on: July 15, 2017, 07:15:15 PM »
Thanks for all the photos, quite interesting.
« Reply #17 on: July 15, 2017, 07:47:25 PM »
I really like the "bog oak" scales with the bamboo pins.....great combo! :thumbsup:
« Reply #18 on: July 16, 2017, 11:30:44 AM »
I'm calling this one done.
« Reply #19 on: July 16, 2017, 06:44:56 PM »
Yep, I would say it's done. Nice work, thanks for sharing.
« Reply #20 on: July 16, 2017, 07:04:50 PM »
Beautiful end result Dave, thanks for the tutorial.
I know nothing about knife making, but I was just wondering, after you tempered the steel and you profiled the blade, I noticed that you didn't profile the edge before heat treating. Is that because you were using a pre-heat treated sawmill steel? I always thought a blade was ground within a few thousands of the edge thickness, heat treated, and then finished the edge?
« Reply #21 on: July 16, 2017, 07:24:15 PM »
I annealed this before I started.  After the initial profile and drilling for the pins, I heat treated the blades.  I like to heat treat the blades before I start grinding because I have found that there is less chance of warping during the heat treat process.  The trick is then that you have to be super careful while grinding to not change the temper.  That took a bit of practice, but so far, so good.
« Reply #22 on: July 16, 2017, 07:32:27 PM »
Thanks for the explication Dave. I'm always amazed at your knife building skills and techniques. I can't imagine the hours it'd take to develop the skill.
« Reply #23 on: July 16, 2017, 08:19:05 PM »
Excellent work crash!  That's a handsome package
Offline SamD
« Reply #24 on: July 16, 2017, 09:48:13 PM »
I agree the pictures show  beautiful contrast in the grip materials!
SamD
U.S. Army Paratrooper, DAV (life member), American Legion (life member), NMLRA (1 of 1000 member) & (life Member), NRA (life member)
"BY THE RUDE BRIDGE THAT ARCHED THE FLOOD. THEIR FLAG TO APRILS BREEZE UNFURLED. HERE ONCE THE EMBATTLED FARMERS STOOD. AND FIRED THE SHOT HEARD ROUND THE WORLD!"
« Reply #25 on: July 17, 2017, 03:39:59 AM »
Great job as always Dave. That's my favorite size to carry for EDC.
Where did you find the bog oak?
« Reply #26 on: July 17, 2017, 04:01:18 AM »
This piece was sent to me as part of a trade for the knife.
« Reply #27 on: July 17, 2017, 07:59:41 AM »
This bog oak really intrigues me as a knife handle material, both its appearance and durability/longevity really appeal to me.....maybe because I'm in the early stages of fossilization myself. :-\     I'd heard of it before, but didn't know the particulars or advantages of using it for knife handles.  It almost sounds like nature's version of wood-micarta from the Wiki description.....
https://en.m.wikipedia.org/wiki/Bog-wood
How was it to work with, Crash.....any impressions or tips you are willing to share?  :shrug:
« Reply #28 on: July 17, 2017, 03:12:41 PM »
This was very easy to work with.  I know who sent it to me, but not sure where he got it.  He can chime in if he wants to.  My experience with bog oak is pretty limited.  The first knife I made with it was recently.  I personally cut a few pieces off the log that it came from.  It was very dense.  Of course, there is quite a bit of cracking on the log, which I'm looking at filling with a contrasting color - it might make for an interesting effect.
This piece was quite a bit lighter than what I have used before.  Again, I don't know the history of where it came from.
Offline SamD
« Reply #29 on: July 17, 2017, 08:37:39 PM »
It is Russian, Radio Carbon dated to 2720 +/- 40 years old by Marzeev Institute.
« Reply #30 on: July 18, 2017, 04:32:17 AM »
OK - cat's out of the bag.  Sam D can answer any questions about the scales.  Hope you enjoy the knife Sam.
« Reply #31 on: July 18, 2017, 08:51:13 AM »
I see that there are several Ukrainian vendors on eBay that sell bog-oak scales.  I have ordered stuff from China and it came faster than most things I order from the U.S.A......but I don't know how fast Russian mail is. :shrug:
Offline SamD
« Reply #32 on: July 18, 2017, 10:05:50 AM »
Snail when I ordered.  :)
« Reply #33 on: July 18, 2017, 10:21:08 AM »
Figures. :-\          Weeks.........or MONTHS? :shrug:
« Reply #34 on: July 18, 2017, 07:00:00 PM »
It's Russian right along. Should get to you in no time.
 :rofl: :rofl:
« Reply #35 on: July 18, 2017, 09:17:37 PM »
Beautiful work, as usual. :thumbsup:
I like the American flag stamp too.  8)
« Reply #36 on: July 18, 2017, 09:28:12 PM »
I always enjoy your videos and WIP's and this one is no different. Nice work!
Congrats, Sam.  :cheers:
