Author Topic: Heat Treat  (Read 22487 times)
Heat Treat
« on: January 10, 2015, 03:38:48 PM »
Just got done doing a blade, and thought I would try something different with the forge. Had a firepit full of charcoal, so I threw a few scoops in to see what would happen. Much to my surprise, I just hit 63.5HRC on O1 tool steel. It's the hardest I have been able to get it with the method I use. I am following my normal recipe, so we will see what an hour does at 400 in the oven...
Re: Heat Treat
« Reply #1 on: January 10, 2015, 03:52:42 PM »
That right there is cool. I don't care who you are. Will be interesting as to the reading after temper. Maybe you should use this blade as a pass around so we can build a data base! If you make it too hard it will break ya know...
Creek  :chopwood:
Re: Heat Treat
« Reply #2 on: January 10, 2015, 03:57:08 PM »
Creek  :chopwood:
I know, that's what I am worried about. I may have to do a second temper at 450 if it comes in too high. 400 usually drops me 2 points, so I may just have to change my method if this is consistent. I will post the results after its done. And I may just pass this one around, as it is my revised bushcrafter. Subtle changes make big differences, and I would be curious to see what everyone thought of this new blade. :thumbsup:
Re: Heat Treat
« Reply #3 on: January 10, 2015, 04:05:41 PM »
Maybe you're getting some extra carbon from the wood charcoal.....I've read that it's a possibility. :shrug:
Re: Heat Treat
« Reply #4 on: January 10, 2015, 04:13:19 PM »
Will you draw back the temper on the spine? Might help with a blade that hard.
Re: Heat Treat
« Reply #5 on: January 10, 2015, 04:14:05 PM »
I have read that as well, but I never put much stock in it. Until now, that is lol!
Re: Heat Treat
« Reply #6 on: January 10, 2015, 04:15:39 PM »
Nah, I don't ever do that. Not sure if I mentioned it above, but this reading is right out of the quench. This is the ideal reading for O1 out of the quench, then you temper it back down to 58/59. This one is in the oven tempering right now, just don't know if it will be enough, or if I will need to temper again at 450
Re: Heat Treat
« Reply #7 on: January 10, 2015, 04:20:02 PM »
I defer to you the expert. I think two tempers would be better then one? The second would not change the hardness but stabilized the steel. Am I wrong?
Re: Heat Treat
« Reply #8 on: January 10, 2015, 04:38:55 PM »
AM I WRONG?      Some raw language, but I couldn't resist.......delete if you have to, Red. :-[
Re: Heat Treat
« Reply #9 on: January 10, 2015, 04:45:53 PM »
Nope, not wrong at all. But I may need to do a second temper cycle at a higher temperature to get to my desired hardness of 59HRC. You got it right bud :)
Re: Heat Treat
« Reply #10 on: January 10, 2015, 05:21:57 PM »
Good chuckle wolfy  :lol:
Re: Heat Treat
« Reply #11 on: January 10, 2015, 05:30:36 PM »
Sounds like me when I'm drunk... well like all the time... ???  Put in a big fart and all my friends and family will understand.
Re: Heat Treat
« Reply #12 on: January 10, 2015, 05:32:53 PM »
Right on the money ;)
Re: Heat Treat
« Reply #13 on: January 10, 2015, 07:26:05 PM »
Looking great Steve!
Seems like you nailed the heat treat.
Re: Heat Treat
« Reply #14 on: January 10, 2015, 09:09:51 PM »
Here's my still-in-the-research-and-learning phase opinion.  I think adding the charcoal allowed you to get the blade more consistently heated throughout, possibly a little hotter than you were previously getting because of the open chamber of the block, and a tad hotter when it hits the quench.  The charcoal takes up space, preventing as much airflow within the chamber, while at the same time retaining more quantity of heat allowing the steel to be in the austentising (sp?) temp range longer, having more carbon in solution when it gets quenched and transforms.   You know what I mean....
I personally don't go for the absorption of carbon idea.  While carbon is present in so many things, the carbon present in knife steel composition is different from the carbon in used motor oil that is used as a quenchant, different from the carbon in charcoal, etc.   If you could actually add (or change) the amount of carbon in the steel, you'd never be able to get it heat treated because you'd never know how much was "actually there" and it would be a new hybrid every time.
Granted this is all just my opinion from the research I've been doing (trying to learn as much as I can) but what I think occurred is the dynamics of your HT procedure changed enough to alter the transference process, albeit in a good way.
Regardless, I think it's awesome!  It will be cool to see if you can duplicate it again next time, which I'm sure you're already thinking about!!  Since the target as-quenched Rc is 64 for O-1, you couldn't be any closer and your HT is better...all very cool!!!!!!!
Re: Heat Treat
« Reply #15 on: January 10, 2015, 09:16:28 PM »
I also am interested in if this can be repeated. It is cool. I for one hope you can repeat it.
Re: Heat Treat
« Reply #16 on: January 10, 2015, 09:17:05 PM »
And.... it's threads like this that convince me I have no idea what I'm doing yet! :)
HT... it's like alchemy. :rolleyes:
Re: Heat Treat
« Reply #17 on: January 10, 2015, 10:23:32 PM »
I have a theory as well Dano. I think what happened was the charcoal burned up the excess oxygen in the chamber, allowing for a more consistent temperature throughout the blade. That torch I use gets upwards of  3000 degrees, so getting hot isn't a problem. Keeping the steel uniformly hot, that is another story :)  I have actually done a LOT of research on how steel was made in the old days (Viking's etc..) and in order to actually ADD carbon to steel, you have to add it to the raw iron.
Anyone who hasn't seen this before, this is your homework: Give me an hour of your life, and in return I promise you will enjoy the whole program :D
Re: Heat Treat
« Reply #18 on: January 15, 2015, 10:23:54 PM »
This is quite interesting. I know 01 is a good steel, but not always easy to HT. I'm glad tou got this so nicely! Looks like my next knife may be 01 :)
Re: Heat Treat
« Reply #19 on: January 16, 2015, 05:09:55 AM »
Great program! Watched it on Netflix a while back. Fascinating!
Re: Heat Treat
« Reply #20 on: January 16, 2015, 11:56:30 AM »
Watched the vid - awesome!
Confusing thing is that the heat treat using these old methods is no where near the science it seem to be these days. Makes it kind of confusing for newbies like myself. Some people seem to take it pretty lax, others seem to really get scientific.
:crazy:
Re: Heat Treat
« Reply #21 on: January 16, 2015, 12:06:28 PM »
:crazy:
It all depends on the steel. Carbon steels are far more forgiving than the newer modern steels.
Re: Heat Treat
« Reply #22 on: January 16, 2015, 12:09:24 PM »
I thought we had already pointed this program out some time back.   It may have been in the form of a 'heads up' warning when it was shown on the NatGeo channel, so I have seen it before.   It was really enjoyable viewing it again & it makes me wonder what a bladesmith would need to charge a customer for an Ulfbehrt today?
        :duel:
Re: Heat Treat
« Reply #23 on: January 16, 2015, 12:22:24 PM »
        :duel:
Based on how much work I saw him put into that sword, (mind you, they never showed the hilt, handle or pommel construction) I wouldn't commit to a project like that for less than $6000.
Re: Heat Treat
« Reply #24 on: January 16, 2015, 12:25:10 PM »
That would be close to what I had imagined. :cheers:
Re: Heat Treat
« Reply #25 on: January 17, 2015, 08:11:46 PM »
Big giant swords on now at discovery ch
Re: Heat Treat
« Reply #26 on: January 17, 2015, 08:21:17 PM »
The viking sword documentary was a great one! I watched it on Netflix a while back. Pretty interesting about the counterfeit ulfbert swords.
Offline NvDesertRat
Re: Heat Treat
« Reply #27 on: January 18, 2015, 05:36:13 PM »
I was always worried about using o1 because I always heard it was to difficult to heat treat with "home" heat treat methods. Your video has me ordering some o1 now. I have a coffee can forge with a forge burner I built from plans online. You can see it on my YouTube channel, MrTrevorm72. What are you quenching your blades in?  Thanks for the video.
Re: Heat Treat
« Reply #28 on: January 18, 2015, 08:51:03 PM »
From my research about HT so far, where you gain in using O-1 over some of the lesser of the carbon steels, comes from the soak time at critical temp.  BUT ONLY if you can accurately monitor and control the temp while it soaks.  Allow it to go too far over temp and you risk losing carbon content, too far under and it won't hit the proper as-quenched hardness, as with any other steel.  But soak it at the right temp for the right time, and you'll have a better finished product over the other carbon steels, same things considered.
That's why if you can't accurately monitor and control the temp, you might as well save money and just use something like 1084 or 1095.   Especially if a person is only using a magnet to check prior to quenching.
Offline NvDesertRat
Re: Heat Treat
« Reply #29 on: January 19, 2015, 12:58:17 AM »
I am primarily using files and rasps right now and I have the heat treat pretty much dialed in for those. I have used 1084 also and I feel confident in the heat treat method I use as well. However, I do not know the temperatures I am reaching in my forge.  And soak time in theory sounds easy enough but I would hate to overheat the steel. I do soak the 1084 for a couple of minutes after I test for non-magnetic and have had good results in the durability testing I have done. Red made it look so easy.
Re: Heat Treat
« Reply #30 on: January 19, 2015, 08:50:12 AM »
I am quenching in mineral oil, pre heated to roughly 150F.
Re: Heat Treat
« Reply #31 on: November 27, 2015, 11:54:38 AM »
Actually, it is common to add carbon to steel after it has been formed and machined.  The process is called Carburizing (NOT carbonizing) and it is done in a sealed-chamber furnace.  A carbon rich gas, like CO and CO2 is added to the chamber and the steel is allowed to soak at about 1700F for MANY hours.  The carbon potential in the gas must exceed the carbon in the steel for the carbon to diffuse into the steel.  Carbon diffuses in steel at about .010" per hour so if you want to develop a high carbon "case" on a low carbon steel, you need to hold it 1 hour for each .010" of hard case you need. After the case has been developed to the desired depth, the parts are oil quenched in a second internal chamber before being exposed to the air.  This process is applied to bearings, pins, gears, splines, etc where a tough low-carbon steel is used to make the part and it is carburized to improve wear resistance.  It is often followed by cryogenic treatment and a double temper.  I have skipped a LOT of the technical details so please don't think this is something that can easily be done in the back yard.  As for the improvement in the blade hardness, it could be a slightly higher temperature or longer time that dissolved the iron carbides more than normal putting the carbon from the carbides into the iron matrix and gave it a boost in as-quenched hardness.
Offline gmusic
Re: Heat Treat
« Reply #32 on: January 31, 2016, 10:50:57 AM »
Hello Red........Quench.
First of all Red, I have enjoyed looking at your pictures, reading your posts and watching the videos you have here.  They are time consuming and you have gone above and beyond to show folks your methods and share your knowledge.
Big thumbs up to you.
Quench........I don't know your background, but metallurgy has played a part in there somewhere (I believe.)  Thank you for sharing your knowledge and experience.   This is quickly becoming one of my favorite sites!
I worked with a Master Smith that was trained in Japan (in the ways old old) after many years he received the equivalent of a MS certificate there.  He then went on to get his MS certification here in the US when he moved here.  He forges with coke then uses pine charcoal when quenching, carburization is the reason for the switch.  To what degree carbon is "added" to the steel, I believe only controlled scientific testing could answer that.  But it makes for great conversation....... ...... Take care
Knives are man's best friend............. .
Re: Heat Treat
« Reply #33 on: January 31, 2016, 11:31:06 AM »
Which is exactly how Jpn sword makers rediscovered their craft, by scientific evaluation combined with traditional experimentation because by the end of WW2 much of the unbroken master to student knowledge was lost.
Great job Red, on a whim, a " crazy idea" you got a great result. That's cool. Have you repeated it yet?
Re: Heat Treat
« Reply #34 on: January 31, 2016, 01:08:06 PM »
Your post got me thinking about this stuff:
http://www.brownells.com/gunsmith-tools-supplies/metal-prep-coloring/color-case-hardening/surface-hardening-compound-prod27119.aspx
Offline gmusic
Re: Heat Treat
« Reply #35 on: January 31, 2016, 02:04:06 PM »
That's interesting PW.  I wonder if using pine charcoal carburizes much the same way, on the surface?
Perhaps Unknown has a link to or can recommend some reading material on the scientific evaluations done after WWII by the Japanese.  It would be a great read!
Re: Heat Treat
« Reply #36 on: January 31, 2016, 03:01:07 PM »
I need to go look at my copy of Art of the Japanese Sword for one to make sure that is the actual title ;D I think it is though
And to see how much detail is there or whether I am recalling a different source, likely both instances, but that book covers it to some degree.
Maybe you can find some details on Iwasaki, seems like he may have been one who did many of the investigations into tamahagane- sorry I'm a bit rusty on many of the details.
You have to remember they are using blooms( though they may not technically be blooms) of varying purity and carbon content and folding to homogenize or even welding different homogenized C contents as laminations. in the process carbon content is lost, as I recall straw is often used to boost it back up to around .7 or so maybe up into the .8s%
Re: Heat Treat
« Reply #37 on: January 31, 2016, 03:17:35 PM »
Liquid and powder forms of hardening compounds have been around for 50+ years.  Years ago, they were poisonous but worked great.  All except the being dead part.  Yes, they do work but they still must obey the laws of physics.  Alloy elements like carbon, nitrogen, chromium, etc., have diffusion coefficients based upon atomic size.  Carbon diffuses faster than chromium for example.  Notice the ads state that the Brownell's compound is a SURFACE HARDENING TREATMENT.  You might get a few thousandths of hardened case.  In other words, you will grind it all off when you sharpen it.   Sorry, no free lunch today.
Re: Heat Treat
« Reply #38 on: January 31, 2016, 03:30:37 PM »
What about the case hardening inside the crucible they sell? Same deal?
Offline gmusic
Re: Heat Treat
« Reply #39 on: January 31, 2016, 04:14:11 PM »
If you find that text Unknown, please give a holler.  Yes, rice straw ash was also used.  After the quench the blade was thrust into the bucket of ash for several hours before tempering.  Interesting stuff.
I had guessed that he powders were surface hardeners Quench, I was curious about the pine charcoal.  I would guess that much like the powder it can't penetrate very deep......but that's just a guess.
Re: Heat Treat
« Reply #40 on: January 31, 2016, 04:27:02 PM »
The carbon doesn't know where it came from: Bone, leather, Carbon Monoxide, whatever.  Once it is in the steel, it diffuses at about the same rate.  To get a deeper case, you have to hold it at heat longer.  Typical GAS carburizing may take 24 hours at 1700F to get a case depth of .125".  The greater the difference in carbon potential, the faster it will diffuse into the steel.  I would expect carburizing with charred bone to work faster but you cannot expect it to go throughout the entire blade.
Re: Heat Treat
« Reply #41 on: January 31, 2016, 09:29:19 PM »
it's actually called The Craft of the Japanese Sword
it talks briefly about adding and removing carbon to get a more even C content. To add carbon it says they stack layers of charcoal and low carbon steel. There's no details on how long or exactly how they burn this pile.
The straw ash acts as a binder to keep the bellows from blowing away the powdered charcoal they use to line the bottom of the forge when burning C off. In the case it describes a stack of steel with charcoal on top with a lot of bellows action.
That's my chopped up summary at least. Not a great deal of detail about the methods employed by the "lost generation" either in rediscovery. Basically rather than keeping secrets, they worked together and used modern metallurgy and steel production to inform their experiments.
Offline gmusic
Re: Heat Treat
« Reply #42 on: February 02, 2016, 09:18:10 PM »
This is all good information.  I was interested in the charcoal method as used by sword and knife makers of old because over thousands of years of trial and error charcoal seems to have produced the best results.  The available carbon in the charcoal as apposed to other materials had to have been superior being the choice still, of blade smith masters today.  All......very interesting stuff.
