Actually was looking at that while putting a battery in the newer 4 wheeler.
Mostly used around "The Place" as there is no level ground unless you make your own...
The are a few local trails along the river.....and a "Slow moving farmers vehicle triangle" on the rear rack gets me down the roads for a ways...mostly....LO L
Has a pull cord that you can get at easy, generally starts with one pull.....
I do have like saddle tank bags on it that have some gear...., pruning shears, fencing tools, several ratchet straps, and tow line.....on board tool kit and spare plug, in a med scrip bottle in cotton balls....tire gauge.
Had a plug get flattened out some from banging around....and cotton balls helps with fire in necessary.
Zip lock has couple of plastic contractor bags, Bic, match case, matches and a couple of tea candles, a cheapo "buck style" knife, leather gloves......full water bottle.
Milk crate has a air compressor, got a slow leak some where,.... only seems to leak in cold weather.
Bunch of bungees, chunk of 2X4 (wheel chuck and fire wood)....all covered up with a GI pup tent shelter half.....cover in rainy weather...or what ever.
That's pretty much it....any other gear would be carried on a "This Mission" only.....
