Author Topic: This should get some glowing recommendations....  (Read 4006 times)
« on: April 17, 2016, 12:34:51 PM »
Been a while since I posted anything new so here goes.
This is a set of 25' x one inch wide Peel & Stick Photoluminescent Tape adhesive backed Afterglow tape and a 100' x 1" roll of Magnetic Photoluminescent Afterglow tape.  This glow in the dark tape has many possible uses at home, in your garage, in your basement, in your kid's rooms, in your vehicle or in camp.
Both rolls shipped to your door for $39.99
Re: This should get some glowing recommendations....
« Reply #1 on: April 17, 2016, 12:49:17 PM »
Cool!
Lots of uses for marking trails at night too. I bet you could write on it with a sharpie and make night visible labels on things as well.
« Reply #2 on: April 17, 2016, 03:11:39 PM »
Now that is something I need to look into! Hopefully some will be around after pay day.
« Reply #3 on: April 17, 2016, 03:34:40 PM »
Not sure if it is the same stuff but we have used LLEPM ( low level elumation path marker) at work. It glows bright and for a long time.
« Reply #4 on: April 17, 2016, 03:40:24 PM »
It may not be the exact stuff but I suspect it is similar.  This particular tape was in kits used to mark the interior of MRAPs so you could stay oriented in low/no light conditions.
« Reply #5 on: April 17, 2016, 04:53:26 PM »
that stuff works great.
extremely common onboard navy ships.
we used to line guys racks (beds) on the inside and leave their light on while they were on watch. they'd get off watch and try to go to sleep and when they turned off their light, blammo!
