Author Topic: drill&file question  (Read 1366 times)
drill&file question
« on: June 12, 2017, 07:58:06 AM »
i'mtrying to drill some pin holes in this 1/8th'in thick file.
i'm using a new 135:split point cobalt bit.
 and the the bit is dancing all over. i even hecked the chuck
to make sure the bit was seated properly.
so any avice on this please.
Re: drill&file question
« Reply #1 on: June 12, 2017, 08:00:03 AM »
Did you anneal it yet?
« Reply #2 on: June 12, 2017, 09:45:44 AM »
Also, make certain the file is not air-hardening steel.  Annealing it like a piece of plain high carbon steel will only make it hard again.  It needs a VERY long slow cooling.  Did you punch a dimple where you want the holes?  A dimple will corral the bit and keep from wandering.
« Reply #3 on: June 12, 2017, 01:30:23 PM »
As has been stated, you will not drill it in its current state with the bits you are using.  It either has to be annealed or you need to use carbide bits.
« Reply #4 on: June 12, 2017, 02:38:06 PM »
well i guess i'll anneael it slow cool see what happens.
thanks everyone. i'll post results
