Author Topic: quick attach snowplow mount.  (Read 3226 times)
« on: November 18, 2017, 03:25:19 PM »
Winter is coming. Lots of mixed news as to how bad it'll be. My Old Chevy is on it's last legs with a broken frame and trans mount.
I have started the John Deere at 20*F easily, so I'm  putting my trust in it's ability to start for me all winter.
I bought a 3/4"x4" steel bar and used some scraps I had laying around. I drilled the bar, bucket and it's mounting bracket to 1/2". This assures the pressure of the snowplow will be pushing directly against the loader arms.  I used a section of the big bar, a smaller thick walled square, and a piece of angle. 3 grade 8 bolts hold it all on the tractor.
Here is the back of the top link with the 1/2" bolt locking it to the bucket.
This top link is supported by the angle piece welded to the 3/4" plate. This takes a substantial amount of pressure off the top edge of the bucket. You can see the bottom center section of plow mount off the chevy welded to the 3/4" bar. There is nothing touching the cutting edge of the bucket and I can tilt it down to remove the chain from the top link.
I am going to plug the hydraulic lines into the bucket tilt remotes. That way I can angle the plow and lift it up to the fullest for some really tall snowpiles!! I will be able to pull the pins and chain then switch the lines back to the bucket and use the bucket alone. so the plow will quick attach to the bucket and the plow mount is quick attach by 3 bolts. Can't get much easier.
To show it in real time, and you can see the bucket has no flex at the end of the video.
Re: quick attach snowplow mount.
« Reply #1 on: November 18, 2017, 04:10:32 PM »
Nice! XJ, I think you're the King of DIY'ers.  ;D
« Reply #2 on: November 18, 2017, 04:33:38 PM »
Now that is pretty slick.....great thinking.
Congrats
Let us know how it works.
« Reply #3 on: November 18, 2017, 05:13:56 PM »
Looks like you did a good job figuring that one out.
« Reply #4 on: November 18, 2017, 05:18:55 PM »
When it comes to metal anyway. I learned that cutting oil makes a huge difference in keeping drills sharp and Cobalt is the way to go!!
Congrats
Will do. I'm a little concerned about the mounts on the back of the bucket fatiguing the welds. I'll need to rely on the plow shoes when pushing snow to keep the stress off them. I was hoping to control height by arm cylinders but I'm not going to risk it.There is no stress on those brackets when the plow is resting on the ground, only while lifted.
Thank you.
Offline dancan
« Reply #5 on: November 19, 2017, 06:42:18 AM »
Great build !
You gonna put in a pressure relief/bypass in the hydraulics in case the plow hits something solid ?
« Reply #6 on: November 20, 2017, 03:21:46 AM »
I don't think so. The bottom cutting edge flips backwards when it hits something. Not sure what plow it is. My old fisher the whole blade would tilt forward and jump over.
My driveway and front lawn is very flat and mostly sand so there isn't much to worry about.
« Reply #7 on: November 28, 2017, 10:59:40 AM »
OOOPS!! I think the last 15 feet of wire on the 10lbs spool was without flux. The setting could have been too low too. Anyway the small square pulled right off the plate.
So I decided to give it more beef and triangulate the top link to lessen the pull on the bucket even more. I used the snow plow fittings for quick release hoses up front. This way I can plug in the log splitter up there as soon as I build it...
I had to order the ends that plug into the tractor because no one had them, be here Saturday. This top bar is almost 1" thick and has that natural curve in it. I think it was once a draw bar. Most of the down pressure is right on the large 3/4" bar in the bucket, with a little lift on the back of the top edge. It still comes off by just the three bolts. That weld still looks sketchy, especially on the angle at the top.
« Reply #8 on: November 28, 2017, 11:57:35 AM »
Neat! You really have a talent for metal fabrication.
« Reply #9 on: December 03, 2017, 04:02:20 PM »
Thank you. I enjoy it. I am really bummed that the four ends I ordered online were wrong. I got the two right ones from a John Deere dealer and find they are 3/8" JIC fittings and I have 1/4" NPT hose ends. So $16 more for some mixed up fittings and I now have full angling capabilities. I pushed a huge pile of dirt from the pond effortlessly today. I changed the antifreeze and added air to the front tires. I think I'm ready for snow.
All they had for male 3/8" JIC were a 90* angle to 1/2" male NPT, so I grabbed a 1/2" female to 1/4" female pipe fitting.
Then a 3/8" male jic to 3/8" male NPT, so again a 3/8" female NPT to a 1/4"female NPT.
I had to loosen the hose bracket and move it in toward the tractor to gt that straight pipe setup to line up. The loader mount was in the way.
I'll get some video.
« Reply #10 on: December 13, 2017, 04:09:48 PM »
 >:( NO! No! No! OOOOOOOOO!!!! Dang it all!!!
Remember back when I was going to buy this I said, People expect too much and over work their machine? Yes, I did.
My welds held fine and the plow functioned perfectly. Until the right outer axle housing cracked. I heard it and got off the machine to check all my welds. They were fine. Then the right front wheel stopped going round. Oh look, gear oil.everywhere.
Just a $300 OOPS! Um, I'll be using just the loader bucket for the rest of the winter. :-\ :-[
« Reply #11 on: December 13, 2017, 05:09:13 PM »
Loaders are notoriously hard on tractors, especially when people start using them for tasks above what they were designed to handle.  Unfortunately, almost everything we do with them turns out to be something that is.  You probably did not get an instruction book with it, but it it would behoove you to try and find one.  The book will tell you what to avoid and the capacity & its limits.  Add-on blades and larger capacity buckets than the loader and tractor were designed for are both to be avoided.  I guess I should have mentioned that earlier. ;D
« Reply #12 on: December 14, 2017, 06:58:21 AM »
I do have the book. It basically say's if you don't need a ballast box in the rear you're okay. adding ballast and loaded rear tires will get you in trouble. The plow is around 750lbs and I have a 980lbs lift capacity. Trouble is it sit too far forward I think.
I haven't got the whole axle apart yet. I'm wondering if I did something wrong when I assembled it after the new bearings and seals were installed. I'll go step by step by the book on disassembly and see what pops out as a mistake.
« Reply #13 on: December 14, 2017, 08:54:05 AM »
It's quite possible that you did absolutely NOTHING wrong.  You know what the old bumper sticker says...... happens! :rolleyes:
« Reply #14 on: December 14, 2017, 10:03:38 AM »
Murphy was an optimist.
« Reply #15 on: December 14, 2017, 02:34:45 PM »
I talked to the local JD dealership and Hoye which is the yanmar parts dealer. Both agree this wasn't caused by over loading. Hoye thinks the parts were not completely pressed together leaving a little wiggle room in and out. JD thinks there was a misalignment of the gears causing excessive force on the ring gear. ( by moving in and out?)
I think I'm going with JD on this one. I didn't paint the ring gear and check the wear pattern like you would with a car. I replaced the shims with new matching shims.  They also questioned the bearing on the spur gear but that is also new and there is no play there.
The outer housing that cracked is a dust shield sort of. The new replacement doesn't even have that piece and I was assured mine doesn't need replacing. That saves me $250. New bearing on the way. I still have shims from the kit I bought last time.
In this second picture, you can see the bolt sticking up. That is a mounting bolt you use to press the housing off the knuckle. That flat surface between the two holes on each side of that bolt is the shim area. The shims connect two bolts and there are four of them. 8 bolts total. Now I'm wondering if one of the shim stacks was way wrong. The shims are thin and stick together. you think you have one but it could actually be 3. 3 thin match one thick.  It's too easy to mix them up.
« Reply #16 on: December 14, 2017, 02:48:34 PM »
So, when you talk about the spur gear, are you talking about the pinion?   My tractor doctor would never replace a ring gear without also replacing the pinion gear at the same time.  Both of them will be stressed to the max if they are not matched perfectly and allowed to wear in at the same rate.
« Reply #17 on: December 14, 2017, 05:09:57 PM »
Yes. This I called a spur because it's in a fixed position. basically no backlash adjustment just back spacing. If I have that right. There sin't any visible damage to either one. I hope they don't need replacing. The ring is $500.
« Reply #18 on: December 14, 2017, 05:27:27 PM »
