Author Topic: best quench oil for 01-tool steel  (Read 1019 times)
« on: November 21, 2017, 07:29:43 AM »
well I've been wanting to order some 01 tool steel.
and was wanting to know the proper oil to quench it.
i read that 01 has better edge retention than say 1095?
is that so? so what say you.
i'm ordering the steel this morning.
Re: best quench oil for 01-tool steel
« Reply #1 on: November 22, 2017, 04:06:26 AM »
I prefer Canola oil (less stink).  Make sure you heat it up to about 120 - 140.  O1 does not like a cold quenchant.
« Reply #2 on: November 22, 2017, 04:46:31 AM »
Thanks crash i have a old turkey roaster you know the hamilton beach.
it goes upto 500'degrees and my quenching tank will fit right in.
i can believe the difference in cost between 1095 and 01 when you buy
1/1/2x36x3 /16ths. wow
« Reply #3 on: November 22, 2017, 01:14:43 PM »
I used mineral oil and it seemed to work well.
Offline 1066vik
« Reply #4 on: November 22, 2017, 10:05:24 PM »
I use peanut oil - it works as well as canola and has a higher flash point.
plus I can get lightly used peanut oil from folks frying turkeys tomorrow.
the actual best quenchant for O1 (& 1095) is Parks 50 -- which is a petroleum blend specifically for HT-ing metal.
