Author Topic: Becket hitch? My way?  (Read 6991 times)
« on: December 08, 2017, 08:00:41 AM »
Not sure I'm doing it right either but the way I do it, has not failed yet. I hang inside all the time.
Basically a slipper half, if on the tree side, and a becket on the hammock side right?
Re: Becket hitch? My way?
« Reply #1 on: December 09, 2017, 06:18:43 PM »
Not sure if you are asking if your method is correct, it looks right to me. I prefer cinch buckles with webbing on tbe hammock end and a carabiner for the tree end.
I did watch this method and it looks like yours.
https://theultimatehang.com/2016/04/25/hammock-becket-hitch/
« Reply #2 on: December 10, 2017, 05:08:19 AM »
That proves it then. I never saw that info graphic before. Thank you.
 I made this video as a response to someones video where it was above the continuous loop. I've never been able to get that to hold. Derek says it can be on either side though. Maybe I tie it wrong above the loop?
Do you have to add a half hitch to ensure the buckles don't slip? I tried a buckle and a descender ring setup both slipped.
This becket stays put quick and easy and only straps are needed. Nice having the biners at the tree though.
« Reply #3 on: December 10, 2017, 07:16:37 AM »
Tying the Becket hitch above the loop is similar to tying a rope halter on a horse with the half hitch above the loop, it will slip and your horse would be free.
With the ring setup I tried 4 years ago it always slipped without the backup half hitch. I got tired of this setup quickly and researched for a better system and found the cinch buckles from Arrowhead Equipment and still use this today on my day hammock. This setup has has never slipped on me.
I won a Dutch hammock last year with the 'Beetle Buckle' cinch buckle system, I have only used this hammock a couple of times and it hasn't slipped neither.
Offline Eikanox
« Reply #4 on: November 28, 2019, 02:13:49 AM »
The feeling of me now is very glad to be with everyone here.
« Reply #5 on: November 30, 2019, 02:19:02 PM »
I've since been using the reef knot. Very easy, never slips , and unties super easy.
