Author Topic: Skottle  (Read 2514 times)
Skottle
« on: June 09, 2018, 06:55:30 AM »
Crash dropped off my new Skottle cooker yesterday.  I certainly appreciate all the effort he expended in scoring this for me.   I fired it up and cooked bacon.   Works great,  cleans up easily.  My new favorite way to cook in camp.  Or at home in the back yard.
Re: Skottle
« Reply #1 on: June 09, 2018, 06:59:00 AM »
:cheers:
Never heard of that before. Wok cooking is one of my favs, and that looks like a sweet rig.
Awhile back I picked up an adapter so I could fill my 1 lb Coleman bottles from a standard 20 lb propane tank.  It has saved me a ton of money, and I don't have to be so stingy with using up my little tanks.  8)
Re: Skottle
« Reply #2 on: June 09, 2018, 07:59:28 AM »
There were 3 at our last Krac camp.  Some delish grub coming off them.
Re: Skottle
« Reply #3 on: June 09, 2018, 08:50:07 AM »
In the southwest they are called discos, and used to be made from old plow disks. There are great to cook on.
Re: Skottle
« Reply #4 on: June 09, 2018, 08:53:33 AM »
Orbean beat me to it.  Don't know where the term Skottle came from.  Always called them a disco or a discada.  I've had a couple of them for years.  A small, shallow one for camping and a large, deep one for the backyard.  They're great to cook on.
Re: Skottle
« Reply #5 on: June 09, 2018, 10:00:47 AM »
I recently took two old gas BBQs to the salvage yard. I saved the side burners from both of them.  I'm thinking an old wok, a little hardware and those burners might turn into one of these gadgets.
Re: Skottle
« Reply #6 on: June 09, 2018, 02:48:56 PM »
Skottle is a South African word.  The cooking disk for this one is made by CarolinaCooker.  They sell it for $32 bucks or so,  and it designed to use a fish or turkey fryer burner.   Mine has legs welded on, and studs to hold the Coleman propane burner.
Re: Skottle
« Reply #7 on: June 09, 2018, 03:14:53 PM »
 :thumbsup: :thumbsup: :thumbsup:
Re: Skottle
« Reply #8 on: June 09, 2018, 06:15:22 PM »
What kind of burner is this one using?  It looks like the kind that those little portable stoves that screw onto the propane bottle use.
« Last Edit: June 09, 2018, 06:20:56 PM by wsdstan »
Re: Skottle
« Reply #9 on: June 10, 2018, 04:51:33 AM »
you are exactly right.  It's a Coleman single propane burner,  that was designed to just sit on top of the one pound propane bottle.  It fits between studs welded onto the bottom, and is held there by washers and thumb screws.  Works perfectly.  Easy on/off for transport or storage
Re: Skottle
« Reply #10 on: June 10, 2018, 06:48:17 AM »
Thanks, I have one of those stoves and live in an area where there ought to be some plow discs laying around somewhere.
Re: Skottle
« Reply #11 on: June 10, 2018, 09:48:31 AM »
You homemade skottle-builders (or 'discada' in my neck of the woods) may want to check with the local implement dealers.  Until the iron-scapping dude comes around, most dealers will have a neat, nested stack of nice land-polished discs lying out back in the iron pile.  They get smaller in diameter from wear and rolling or sharpening.....when one breaks from hitting a rock, they usually replace all of them, otherwise one would be bigger and run deeper than the rest of them in the gang.  The scrap yards would be the next logical source, but they would probably be harder to locate after they get dumped off in the pile of everything else. :popcorn:
Re: Skottle
« Reply #12 on: June 10, 2018, 12:09:04 PM »
With an adapter and hose, a 20 lb bottle hooks up to it nicely.
Re: Skottle
« Reply #13 on: June 10, 2018, 01:14:24 PM »
Sure does.  This is one I cobbled together from an old plant stand.
Re: Skottle
« Reply #14 on: June 10, 2018, 01:52:09 PM »
Last night, I cooked some country ribs with the skottle.  Quick and easy. I was impressed
Re: Skottle
« Reply #15 on: June 11, 2018, 07:13:30 PM »
At the last few camps, all I brought was the skottle.  Worked great.  OK-----full disclosure......... .....Greg was there and the Dutch Oven goodness was abundant.
Re: Skottle
« Reply #16 on: June 12, 2018, 08:16:50 AM »
honesty is good for the soul.   lol
Re: Skottle
« Reply #17 on: June 12, 2018, 02:09:37 PM »
LOL, the dutch ovens were only brought to bake Cinnamon Rolls, Soft Pretzels, Banana Crunch Muffins, Hash Brown Casserole, and a 14" Deep Dish Pizza...
Re: Skottle
« Reply #18 on: June 12, 2018, 04:53:13 PM »
Maybe so, BUT try cooking those scrumptious delights on a 'skottle!'  :lol:
Offline Pete Bog
Re: Skottle
« Reply #19 on: June 12, 2018, 11:04:23 PM »
Has anyone here actually tried to fabricate one of these? I've got a double fistful of the discs but they all have a hole in the center for the axle shaft to pass through. Is there a type of disc that does not have a hole in the center? I don't think I have ever seen one.
If you do fill in the hole in the center of the disc, how do you get it smooth enough to pass a spatula over easily and sealed tight enough not to leak cooking liquids. My discs are a hardened steel to withstand the wear of being pulled through the soil, and a bugger to weld on. (Disclaimer: I'm not very skilled at welding, but I'm not a total klutz either)
I just got some 55 gallon drums and I'm thinking it would be easier to hammer a dish out of a drum top than it would be to fill in that hole in the ganged disc used for soil conditioning.
guidance anyone?
Re: Skottle
« Reply #20 on: June 13, 2018, 11:37:38 AM »
Just weld a shaped metal square to the disc and then fill the other side with welding rod.  Grind to shape.
I think a metal drum top is too thin to give much service life as a cooker but it could be worth a try.
Offline Pete Bog
Re: Skottle
« Reply #21 on: June 13, 2018, 05:00:55 PM »
OK, I'll give it a try later this summer.
I wouldn't think the drum top would be any less durable then the metal in those Weber charcoal grills. But your right, there is probably not much service life in those thinner metals.
Re: Skottle
« Reply #22 on: July 20, 2018, 07:54:35 AM »
A quick breakfast on the Skottle this morning. This one is going to Tony at our next camp.
Re: Skottle
« Reply #23 on: July 20, 2018, 07:58:25 AM »
I can't wait.  I've been thinking about all the things I can cook on it.
Re: Skottle
« Reply #24 on: July 20, 2018, 10:22:30 AM »
Yellowyak, what was that disc from in it's original life?  It looks like the perfect size.
Re: Skottle
« Reply #25 on: July 20, 2018, 01:02:05 PM »
I believe a plow disc of some kind. 18" in diameter. Has the center hole welded up. It's a great size, thanks.
Re: Skottle
« Reply #26 on: July 20, 2018, 07:27:12 PM »
Thanks..... I think my neighbor might have some of those.
Re: Skottle
« Reply #27 on: August 02, 2018, 11:00:29 AM »
Skottle Smoker Test
Wanted to test smoking on the Skottle, so I purchased a small quantity of chicken wings for my test.
Placed a piece of aluminum foil on the Skottle and some hickory chips on the foil:
Put water in a cake pan and put on top of the wood chips:
Put a wire rack on top of the water pan and put on the chicken wings with a little rub mix on them:
Lined my bowl / lid with foil around the rim to attempt to keep in as much smoke as possible:
Cooked to 165 degrees F. Took a little over 1.5 hours with the Skottle burner on medium low:
They were good as is, but I called my son to come home to pick up lunch. He wanted his hot. Mixed up a little butter and Franks hot sauce. He took his to go:
I'll definitely be doing this again, it worked great.
Re: Skottle
« Reply #28 on: August 02, 2018, 11:06:03 AM »
You are the man.
Re: Skottle
« Reply #29 on: August 02, 2018, 05:51:24 PM »
Those look really good.
Re: Skottle
« Reply #30 on: August 02, 2018, 05:53:38 PM »
Just had wings for supper and they were good, but I don't know if they were as good as those look!
Re: Skottle
« Reply #31 on: August 03, 2018, 05:28:08 AM »
I love my skottle.
