Author Topic: Quick poll.....What is the easiest way to cut micarta to shape ?  (Read 3853 times)
Offline bendobebaby
I can't seem to find the easiest way to CUT micarta to shape.
Opinion needed on what kind of machines, saws, techniques etc...you guys use to tackle that hard micarta.
Please help me and make my life a little less miserable.  :)
Offline C3 Knives
Re: Quick poll.....What is the easiest way to cut micarta to shape ?
« Reply #1 on: October 06, 2012, 11:42:24 AM »
Micarta cuts pretty easy with a scroll saw. G-10 is easier to sand to shape... IMO
Offline NMTracker
    • NatRevGA
« Reply #2 on: October 06, 2012, 11:46:49 AM »
By hand, the only thing I have used successfully in the past has been a coping saw.
Offline bendobebaby
« Reply #3 on: October 11, 2012, 02:58:54 PM »
Thanks .  I'm going with the scroll saw.......I have to cut a bunch time to time and I think the scroll saw will be easier than cutting by hand.  :)
« Reply #4 on: October 11, 2012, 03:27:53 PM »
I don't have a scroll saw so I have used a coping saw to cut it. When I am cutting scales from a larger sheet of material I just use my table saw. Mostly though for removing moderate amounts of the stuff I just grind it away with a 36 grit belt.
« Reply #5 on: October 11, 2012, 05:18:46 PM »
i use a scroll saw as well, a fresh blade will cut it like butter :thumbsup:
Offline knifeguy
  • Hobbyist Knifemaker
« Reply #6 on: October 13, 2012, 02:53:45 PM »
I don't have a scroll saw, so I cut it with a bandsaw, and then grind it to shape.
« Reply #7 on: October 13, 2012, 03:03:13 PM »
Band saw is even better than a scroll saw IMHO.  But both would work fine.
Offline JustJoel
    • Smoke in the Cedars
« Reply #8 on: October 13, 2012, 03:34:25 PM »
Bandsaw to shape, oversized.  Pin and Glue then drum sand to fit.  :)  Just my $.02...
-JP
« Reply #9 on: October 13, 2012, 04:00:04 PM »
That's the way I do it, too JJ.......except I use a belt grinder :thumbsup:
Offline C3 Knives
« Reply #10 on: October 14, 2012, 06:46:20 AM »
I have a band saw as well and it is good for rough shapes, and breaking down blocks of wood.  The scroll saw is far better for detail work, and is $60 at Harbor frieght. My band saw was $300. You can get a cheap one for around $120 but they don't work well at all IMO. The cheap scroll saw from HB has been crankin for over 2 years now, and works pretty well. More than one way to skin a cat...
