Author Topic: Look what followed me home yesterday  (Read 11683 times)
« on: March 09, 2013, 09:16:11 AM »
The ultimate off road bug out trailer! Just $1500!
Military M1102 trailer designed to tow behind the HMMWV. This trailer is super rugged and is a great work, camping, expedition or bug out trailer.
The trailer has a military spec pintle hitch,  Built in to the hitch is a surge brake assembly giving it brakes without any special wiring required in the tow vehicle. It also has independent parking brakes for parking on a hill.
It has a full independent tailing arm suspension with shock absorbers, meaning it has a great ride and also has a whole lot of ground clearance.
The tires are military HMMWV 37.5x12.5x16.5 with the run flat inserts and are in excellent shape. It uses a standard one ton 8 lug pattern so you can swap smaller wheels/tires or swap to match your tow vehicle.
The body is all aluminum with cargo tie down points and a tailgate. It even has a military Jerry can mount built in as well as landing legs for the back that attach to allow you to load it or camp in it with it disconnected from the tow vehicle.
Still has the military wiring, I can provide instructions for converting to a regular 4 flat plug or can do it for the buyer for $20.
The government paid over $8000, this is a steal at $1500. Perfect work, camping, expedition or survival trailer- load full of your camping, survival, fishing or other gear and you have it made!
Manufacturers specs:
Maximum Vehicle Weight 4200 lb (1905 kg)
 Curb Weight 1460 lb ( 662 kg)
 Maximum Payload Capacity 2740 lb (1243 kg)
 Hull Unitized body construction using aircraft grade aluminum and chromoly steel
 Dimensions
 Overall Length 132 inches (335cm)
 Overall Width 85.6 inches (217 cm)
 Overall Height 52.5 inches (133 cm)
 Track Width 72.5 inches (184 cm)
 Drawbar Length (from axle center to eye center) 93.2 inches (237 cm)
 Drawbar Eye Height 29.5 inches (75 cm)
 Deck Height 34.5 inches (88 cm)
 Ground Clearance (Laden) 16 inches (41 cm)
 Running Gear
 Suspension Type Fully independent progressive rate trailing arm suspension
 Axle Tubular steel
 Spring Media Progressive rate torselastic rubber chords
 Shock Absorbers Telescopic, direct acting, one per
wheel, HMMWV compatible
 Wheels 16.5 X 8.25, two piece steel, HMMWV compatible, 8 on 6.5 inch bolt pattern
 Tires 37X12.50R16.5 Goodyear Wrangler M/T, with 30-mile runflat inserts, HMMWV compatible
 Brakes 12 inch x 2 inch free backing hydraulic surge brakes with automatic breakaway actuation. Independent lever-operated left and right side mechanical parking brakes.
 Electrical System 24 Volt DC sealed lighting system with blackout convoy lights, 12 pin connector plug mates with HMMWV
Some pictures
Re: Look what followed me home yesterday
« Reply #1 on: March 09, 2013, 09:22:08 AM »
I would love to have one... I don't have the $$ for one, but I would love it!
It reminds me of Les Hiddens( The Bush Tucker man) military trailer he hauled around a lot. I think it would be great for hauling stuff for big get-together outings. like the Kracanueners do...
Those tires look to be about $200-250 US for the pair alone, let alone the rig..
Good deal, the way I see it!
« Reply #2 on: March 09, 2013, 09:22:27 AM »
OMG!  That would look badass behind my Scrambler!
« Reply #3 on: March 09, 2013, 09:26:54 AM »
ACKK!! SO cool!!!! Need a new  8) icon just for that bad boy!!!
:drool:
« Reply #4 on: March 09, 2013, 09:27:39 AM »
That is sweet! Seemed like a great price too!
« Reply #5 on: March 09, 2013, 09:30:04 AM »
My favorite off road trailer ever.   They are a bit more money than they used to be but still worth it.
« Reply #6 on: March 09, 2013, 09:47:25 AM »
« Reply #7 on: March 09, 2013, 10:07:16 AM »
A friend of mine has a similar one of those.
He likes to hit up those government auctions. He's got all kinds of stuff including one of those huge 6x6 transport trucks.
He's going to mount a .50 cal BMG on the back with a turret. And yeas he has all that stuff too... Hell he's even got an old fire lookout tower :shrug:
Oh... And he's also got 5 Chez military surplus fighter planes and his own hanger to put them in ;)
And yes... He knows how to fly them :P
He's in his late 60's and don't mess around :)
Sorry WB... That trailer just reminded me of him :)
« Reply #8 on: March 09, 2013, 11:10:05 AM »
Man that is sweet.  I've never seen one in that good of shape before.  I can just picture that with a deer in the back and my canoe tied down on it :)
« Reply #9 on: March 09, 2013, 11:17:47 AM »
Clean is right, take a look at the undercarriage,
This thing has seen very little use, heck most of the paint is still on the pintle
, a few scratches in the bed, otherwise this is pristine.
« Last Edit: March 09, 2013, 11:50:18 AM by Wilderbeast »
Re: Look what followed me home yesterday NSN 2330-01-387-5426
« Reply #10 on: March 09, 2013, 02:09:06 PM »
and a couple more shots just because
« Reply #11 on: March 29, 2013, 10:31:49 PM »
Amazing great shape!!!!
Hey, yer gettin' closer...got a line on a M35A1 (turbo) yet?  Desert camo would be nice tho I can paint it too...
;D
« Reply #12 on: March 30, 2013, 05:33:38 AM »
;D
You want a deuce-and-a-half I can get you one.  They had a bunch in really nice condition in desert camo fresh from the middle east at the depot where I picked up this trailer.
« Reply #13 on: March 30, 2013, 06:17:53 AM »
since value is relative.... would you take a GB SFA and some dental floss in trade?
Offline BENCH
« Reply #14 on: March 30, 2013, 06:34:21 AM »
WOW from the pics it looks brand new, and will serve your family for generations :-)
Congrats in a good find
Would rather be judged by twelve, than carried by six!!
« Reply #15 on: March 30, 2013, 06:45:37 AM »
I already have a GB SFA, but dental health is priceless so let me consider it......
No thanks  ;)
Bench,
It's as close to new as any surplus trailer I've seen.  The plate shows it was made in 2009 and it takes a couple of years to run through the DRMO process to get into the surplus pipeline so it couldn't have been used much if at all.
This will serve somebody else's family for generations, it's for sale by owner (me).
Price lowered to $1450 and I'll deliver it for a modest fee (cost of gas and tolls).
« Reply #16 on: March 30, 2013, 08:09:05 AM »
I swear that thing would look good behind my dually :)
« Reply #17 on: March 30, 2013, 08:22:24 AM »
You know they make camper tops for it?  I could be persuaded to trade it away.
« Reply #18 on: June 27, 2013, 11:07:28 AM »
Just walking back in my footprints :)
« Reply #19 on: June 27, 2013, 01:39:26 PM »
That is positively brutishly cool... :thumbsup:
« Reply #20 on: June 27, 2013, 02:00:57 PM »
What you talking about, Willis?
Yup, it is.   8)
Offline Bryan Breeden
« Reply #21 on: June 27, 2013, 05:12:35 PM »
Man that is sooooooooooooooo cool.  I love it.
You lucky guy  lol
Bryan
My vendor Subforum  Breeden knives.
Breeden Knives
« Reply #22 on: June 29, 2013, 04:09:48 PM »
This bad boy has been sold
I'll let you all know when the next one rolls in  :).
Re: Look what followed me home yesterday, again ....
« Reply #23 on: December 13, 2014, 03:01:02 PM »
I just picked up another trailer, this one is an M1101, pretty much identical to the last one.  And I'm getting a second one on Monday.  Since i don't have a need for two, I'll be dealing on these.  They would look awesome behind a dually  8)
My Tahoe pulled this one home with ease, I just needed a 12" rise on the pintle, but putting smaller tires on would drop it 4" and I believe the pintle hook can be lowered a couple more to get it level.  And a buddy put a drop axle on his and it looks great, a low rider M1101  :).
This one can be yours for $1250.00.  I'll deliver within 200 miles of my home for free (212 miles if you pay cash)
Here are some shots of the first new one
I'll post some pictures of the second one later in the week.
