Author Topic: Just Recipes  (Read 108576 times)
Re: Just Recipes
« Reply #200 on: February 15, 2015, 09:19:02 AM »
Wow! That is a tasty looking sandwich! You guys with cast iron pans can use WW's improvised sandwich press by using Tue bottom of a small pan on top of the sandwich with the big pan underneath. I have tried this and it works!
Re: Chicken and Sausage Gumbo
« Reply #201 on: June 21, 2015, 06:42:50 PM »
This is a recipe I sort of came up with on my own. It's an amalgam of several gumbo recipes. "gumbo" is an African word, meaning "okra". But this recipe instead uses file' powder to thicken it at the table, rather than okra in the ingredients. Purists will insist that if it doesn't have okra, it isn't gumbo. However the French Creoles in the country north of New Orleans made gumbo without okra all the time.
Anyhow, here goes...
Ingredients
1/2 cup all purpose flour
1/2 cup vegetable oil (or bacon grease)
1 bell pepper chopped
1 onion chopped
2-3 stalks celery chopped
2 medium boneless, skinless chicken breasts cut into 1" pieces
1 lb. smoked sausage cut into 1/4" thick rounds
1 bay leaf
2 small to medium cloves garlic, minced or pressed
Chicken stock - 2 or more cups
Tony Chachere's creole seasoning
salt and pepper to taste
Gumbo file' powder
Cayenne pepper
long grain white rice
Start by chopping your "trinity" of onions, bell pepper and celery, then put them together in a bowl and set them aside, along with the minced garlic. Then in a big cast iron skillet, brown the chicken and sausage well, and set aside.
In a big pot, add flour and oil (or bacon grease) and over medium-high heat, keep stirring until the flour turns chocolate brown. This is making a roux. You have to stir constantly or it will burn and you'll need to start over. Any black flecks of burnt flour will ruin the flavor.
As soon as the roux gets close to the chocolate brown color, add in the chopped vegetables. This will help prevent the roux from burning. Keep the vegetables moving in the pot just to be safe, for another 30 seconds to a minute. You want them to wilt and glaze a little. They will smell just awesome at this point.
After the veggies have wilted some, then you can add 2 cups of chicken stock, and then the chicken and sausage, and the bay leaf. Also add about 2 level teaspoons of the Tony Chachere's creole seasoning, and add about 1/4 teaspoon of black pepper. If you need more liquid, add just enough to barely cover the contents of the pot. You want them all to be wet, but not so much as to thin out the soup too much. Let this simmer on medium-low heat for an hour. After an hour, taste it and add Tony's seasoning until the heat level is to your liking, then add salt until the salt level is to your liking. Before serving, skim off the excess oil from the surface. Oxo makes a great oil separator for the purpose that is a lot easier than trying to scoop it all up with a spoon. Remove and discard the bay leaf.
While the gumbo is simmering for an hour, you can start your rice so it will be ready when the gumbo is done.
To serve, use wide brimmed soup bowls and place a scoop of white rice in the center of the bowl, then ladle the gumbo around the outside. You can sprinkle about 1/4 to 1/2 teaspoon of file powder onto the gumbo, and a little more on the brim of the bowl and the top of the rice for a garnish. Do the same with a tiny bit of cayenne pepper for color.
This is best served with some french bread garlic toast.
This same recipe can be modified by eliminating the sausage, and using a lot less chicken stock. The chicken breasts are increased from 2 to 4. Brown them as before and set aside. Make the roux in a deep skillet instead of a pot. When the roux is ready, add the veggies and then just enough chicken stock to keep from burning, then simmer covered over low heat for an hour until the chicken is fully cooked and tender. Taste and season as before. Serve this over rice and you'll have a nice chicken fricassee.!
My wife asked me what I wanted for Father's Day dinner, I told her shrimp gumbo. I gave her this recipe and she cooked it up for me. She couldn't find the Gumbo File' seasoning, but it was still mighty tasty. Thanks for the recipe.
Re: Just Recipes
« Reply #202 on: June 22, 2015, 09:03:51 AM »
Looks good! You can also throw in some small oysters and crab meat to really make it nice. A lot of folks put tomatoes in the seafood gumbo.
Offline fuzzfarmer
Re: Just Recipes
« Reply #203 on: January 21, 2016, 01:24:34 PM »
This is an easy recipe for WOLFY'S DEER SUMMER SAUSAGE that I have 'diddled' with for years, but I think I'm finished messing with it now.  I just pulled it out of our recipe file to make up a batch with some burger from this year's buck.  Hope all you deer hunters give it a shot and let me know what you think.  We've received accolades from people that have had it and I've given the recipe out on other forums where it has been quite popular, too.  So, if you've got lots of deer burger to deal with, this is a great way to use some of it, but it works fine with beef burger, too.
3# deer burger
2 T liquid smoke
4-5 cloves crushed garlic....or MORE ;)
1 T whole mustard seed
3 T Morton Tender Quick
1 Cup water
1/4 t course-ground fresh black pepper
1/2 t onion powder
2 T brown sugar
1 T red pepper flakes
METHOD:
Mix all the ingredients together and pour over meat while mixing.......I use the dough hook on our KitchenAid stand mixer.  Form into two logs about 3" in diameter & 12" long.  Seal in foil & refrigerate for 24 hours. Punch holes in bottom of foil with a fork.  Place on broiler pan or cake rack on a sheet pan, so fat can drip out during baking.  Bake 1 1/4 hours @ 325 degrees.  Unwrap & cool.  Wrap with plastic wrap & store in refrigerator or freeze.
I mix up 6# at a time, because 3# just doesn't last long enough around here :stir:
This is kind of a 'basic' recipe that we have arrived at to suit different family members' taste 'prejudices', so feel free to experiment by adding different commonly added sausage ingredients that you may crave 8)
I may have to try this.  Love summer sausage, but had no idea how to make it.
Offline MississippiRifleman
Re: Just Recipes
« Reply #204 on: March 30, 2016, 09:05:51 PM »
My wife made me some of the best sandwiches when we were dating, and her recipe goes something like this:
Start with two slices of your favorite bread (I like sourdough for this one)
Add mayo, mustard, whatever you prefer
Add thin sliced turkey or ham, or both!
Add a leaf or two of your favorite lettuce (Romaine for me)
Add a thin slice, maybe two, of pear or (my favorite) Granny Smith apple
Top with second slice of bread
Press long enough to slightly toast the bread
The apple or pear slice adds a neat flavor to the rest of the sandwich, and is a great summertime midday meal with a cold hefe weizen.
Re: Just Recipes
« Reply #205 on: March 30, 2016, 09:23:10 PM »
 :welcome: to the forum, from NEBRASKA!
Sounds like a good combo! :drool:    Thanks for the recipe. :cheers:
If you don't have a panini press, but you do have an old George Foreman grill in one of your kitchen cabinets, they do make a pretty decent substitute for a sammich like this. :thumbsup:
BTW.....if you get a little time, go to INTRODUCTIONS and tell us a little about yourself and some of your interests. :)
Re: Just Recipes
« Reply #206 on: April 23, 2016, 10:37:12 PM »
Tried this one from Kephart's "Woodcraft and Camping" and I think, judging by the clean plates, I might have a hit on my hands.
Woodcraft and Camping, pg. 356
Corn Batter Cakes -
1/2 pint corn meal
1/4 pint flour
1 heaped teaspoonful baking powder
1 heaped teaspoonful sugar or 2 molasses
1 level teaspoonful salt
After mixing the dry ingredients thoroughly, add cold water, a little at a time, stirring briskly, until a rather thick batter results. Bake like flapjacks. Wholesomer than plain flour flapjacks. These are better with an egg or two added, and if mixed with milk instead of water.
I used two eggs and enough milk to get the batter to drop neatly from a spoon, and cooked them in a greased iron skillet until the bubbles set on one side, then flipping them to the other. They eat like a cross between pancakes and cornbread, with the best qualities of each. I've rolled them up with fruit or preserves inside for a quick morning grab-n-go, and have eaten the leftovers broken up in a glass of warm milk.
Our forebears knew a thing or two about good vittles, I must say...
Re: Just Recipes
« Reply #207 on: April 24, 2016, 01:47:04 AM »
did you use molasses or sugar?
These are one of my favorite foods. Plain and simple. I like them a bit more flapjacky so they crumble less when the plan is to precook at home. Pack 'em in a breadsack, waxpaper, or ziplock. Repackage a can of hatch chiles, precook some sausage, jelly, honey, butter... mmm mmm
I'm glad you posted this. I just got some fresh eggs. Lots of non GM :-X corn flour and grits on hand
Re: Just Recipes
« Reply #208 on: April 24, 2016, 08:04:57 AM »
They sound good to me as well.
Three of them with a sausage link or two (or three) and a couple of eggs over easy and I am a happy camper.   :-*
Re: Just Recipes
« Reply #209 on: April 24, 2016, 09:41:14 AM »
I used sugar, but I'm gonna try some local honey with the next batch.
Offline marchone
  • Always looking for good tools.
Re: Just Recipes
« Reply #210 on: November 27, 2018, 09:23:00 AM »
This variation of a British-style curry uses unripe bananas to thicken it. Swapping cubed chicken breast, grouse or pheasant for the shrimp and scallops are other versions.
Seafood Curry
1 tablespoon Sun Brand or Bolst?s curry powder
1 teaspoon coarse sea salt
6 cloves garlic, peeled, crushed and minced
1 whole celery heart, cleaned and chopped
1 large Spanish or white Bermuda onion, peeled and chopped
1 cup Noilly Prat dry white vermouth
2 cups light chicken broth
2 green unripe bananas, peeled and chopped
1 cup cream
1/2 lb small shrimp
1/2 lb sea scallops
2 tablespoons Thai nam pla or Vietnamese nuoc cham fish sauce
1 cup loosely packed mixed herbs*
Preheat a large shallow pan. Add curry powder and salt and toast lightly.
Add oil and garlic. Cook for 2 minutes over a medium heat. Do not brown.
Add celery and onion. Cook about 10 minutes to soften the vegetables.
Add the vermouth. Reduce by half.
Add the chicken broth. Reduce by half.
Add the bananas and cream. Continue to cook on medium heat till thickened. The bananas will have softened and melted into the curry.
Add the seafood. Cook till the shrimp are pink.
Stir in the herbs. Correct the seasoning with fish sauce.
Serve hot with steamed Jasmine rice, more fresh herbs*, dried coconut, raisins, raw cashews and Major Grey?s style mango chutney.
* Basil, tarragon, chives, cilantro.
Serves 4 to 6 persons
Note: If meat is substituted for seafood don't leave out the nam pla. It is an all purpose seasoning that adds great depth of flavor to most anything.
« Last Edit: November 27, 2018, 01:59:46 PM by marchone »
Wayne
Beer Bread
« Reply #211 on: March 02, 2019, 03:20:57 PM »
I did not search for this bread recipe so if it was posted earlier my apologies.
Beer Bread for the lazy.
A 12 ounce can of beer.  If you get 16 ounce cans drink 4 ounces of it and use what is left.
3 cups of flower.
1 tsp baking powder
1 tsp salt
1/2 cup of sugar (you can use honey or brown sugar if you wish)  I use honey most of the time.
Mix all the ingredients above.  If you use self rising flour delete the baking powder and salt.
Melt a 1/2 cup of butter
Put the mix in a bread pan and spread it out to a uniform thickness.  Pour the melted butter over the mix letting it drizzle around all the top area.  The butter makes a crust on the top.  If you don't want a crust mix the butter into the bread dough.
No rising, no nothing just put it in the oven,
Bake for 1 hour at 375 degrees.  Put it on a rack and let it cool.
I check it at about fifty minutes.  i find that it usually can go an hour to an hour and 5 minutes in my oven.  This is, a heavy bread, and wonderful as is or toasted lightly with jelly or honey.
Re: Just Recipes
« Reply #212 on: March 02, 2019, 04:46:28 PM »
That sounds like it would be tailor made for a quick bake kettle bread, too. :stir:
Re: Just Recipes
« Reply #213 on: March 02, 2019, 05:06:21 PM »
hmmmmm.  I might have to break out some cast iron next week.
