Author Topic: How to tell a morel??  (Read 752 times)
Offline amc317
« on: September 03, 2014, 10:28:15 AM »
Hi, we moved and we had these round mushroom things in our yard and we let one sit to see what will happen and a few days later poof, a morel looking mushroom appears. However the top isnt closed, i washed it off and its white with a yellow stem, its hollow and pitted. after i cut it open before it was cut,
The bottom of the cap is not attached from what we can see. From what i understand it has characteristics of both
Re: How to tell a morel??
« Reply #1 on: September 03, 2014, 11:11:53 AM »
Excellent follow-up post! :thumbsup:     I was hoping you'd show the 'sectioned' false morel.  Some of them are so close in appearance that a longitudinal slice through the middle is the only way to identify them positively. :doh:
Offline amc317
« Reply #2 on: September 03, 2014, 01:06:42 PM »
So this is a false morel?
« Reply #3 on: September 03, 2014, 01:56:49 PM »
Most likely......if the cap is not hooked directly to the stem at its base, it for sure is.   One thing for certain, it ain't a true morel!
« Reply #4 on: September 03, 2014, 01:59:48 PM »
Not sure what you have there. Doesn't look honeycombed enough to be a true morel. What time of the year did you pick it?
Offline amc317
« Reply #5 on: September 03, 2014, 02:14:54 PM »
Uh this morning
« Reply #6 on: September 03, 2014, 02:41:13 PM »
Way past morel "season" in 99% of the country.
